Directlogic dl05 saved program
diat150
Mar 2006
Louisiana
1,474
Is it correct to say that the dl05 program when uploaded does not store the current value in a v memory location?
I have a customer that has one of these that crapped out and when I replaced and downloaded to it none of the v memory values have values. If so that is pretty crappy.
I think the Click or BRX also does something like it, you have to load 'data' and the program, I remember something like that but its been awhile
The 'program' contains the ladder logic. The 'project' contains the ladder logic and the data table contents.
I was able to use the memory editor(I found one of your older posts talking about this) to look at values of the project file that was saved so I at least have that, but is there a way to transfer what was in the project file to the processor?
When downloading use 'Save Project To PLC'. It's in the written menu, not the icon.
'File' - 'Save Project' - 'To PLC'
Thanks so much. Whats crazy is I called AD Support and the tech told me this wasn't possible when I explained to him the situation, he said that the program should have been setup to set the V memory to a default value at first scan. I found it hard to believe thats I why I queried here.
I've only ever done one DirectLogic project, but there were definitely a lot of V-memory locations that were initialized to a certain value on first scan. Most of them were constants, but I think even some V-memory locations used for signals were initialized to a value, which would then just change instantly once the program actually went live and it started reading the inputs. I never tried using the memory editor you mentioned, so I never had process data while offline, it was one of my biggest gripes with the PLC.
Just remember once the program is working properly go online with your fully commented program then use the Save Project To Disk for a complete backup.
what we talked about worked great. I have no clue why AD support told me differently. Thanks again.
Good morning fellow sea captains and wizards, I am being asked to do the above and obtain 4 values from each slave, I know about the MRX and MWX...
32
833
Hello everyone, Background: We have a Directlogic 405 PLC that has an output card that has all solenoids on it. These solenoids are on plugs with...
2,895
Can someone please explain the sinking and sourcing with respect to DL405 series PLC? I have already been through the manuals. Explanations with...
1,998
I'm new to the whole Drum idea. I tried to figure it out but couldn't. I'm wanting to use a drum or sequencer to seqence a V memory depending on...
1,456
any one know how to do PLC-to-PLC Communications over a network using two 205 DirectLOGIC PLCs. I can't even get the example given to work.
2,621
