Directlogic Drum as a sequencer
Dariusincj
Jul 2011
Missouri
43
I'm new to the whole Drum idea. I tried to figure it out but couldn't. I'm wanting to use a drum or sequencer to seqence a V memory depending on some inputs: ie, if C0 is on, V3000 = 1, if C1 is on, V3000=2 but sequence V3000 between them at a set time if both are on. I'm not sure if I am clear on this or if i'm lost.
Good morning fellow sea captains and wizards, I am being asked to do the above and obtain 4 values from each slave, I know about the MRX and MWX...
32
833
Is it correct to say that the dl05 program when uploaded does not store the current value in a v memory location? I have a customer that has one...
3,096
Hello everyone, Background: We have a Directlogic 405 PLC that has an output card that has all solenoids on it. These solenoids are on plugs with...
2,895
Can someone please explain the sinking and sourcing with respect to DL405 series PLC? I have already been through the manuals. Explanations with...
1,999
any one know how to do PLC-to-PLC Communications over a network using two 205 DirectLOGIC PLCs. I can't even get the example given to work.
2,621
