DirectSOFT 6 upgrading from version 5.3.
Elcan
Apr 2008
NC
935
Hello all,
We have an old AutomationDirect DL405 (CPU 440) PLC, and we've been using DirectSOFT 5.3.
Since we are NOT upgrading this PLC for a few years, I was wondering if it would be a good idea to upgrade the software to DirectSOFT 6.
Has anybody followed this route in the past?
Does it worth the cost of the license and the hassle of upgrading?
Do the 5.3 projects convert automatically (and totally) to version 6?
I will appreciate the feedback!
Thank you!
We have version 6.3 and one of our customers still has version 5. Since they don't use any of the new features, and their program is already long and a bit complex, I have not implemented any significant changes to the code, so sometimes I use my laptop with version 6.3 and other times when I need to view it remotely using their PC, I connect with the older version.
I am pretty sure that if I were to save my copy of the file to their machine, that the older version would not open it, so I have made edits to the documentation separately for them.
Here is a good list of the improvements you would get by upgrading:
https://hosteng.com/sw-products/directsoft/DirectSOFT6.htm
Thank you, Okie!
We are not planning on changing the existing code, but I was wondering if the newest version (63. in this case) had a better user interface, easier to do procedures, better online capabilities, etc.
In a few words, have you noticed a real improvement in those areas I mentioned above?
Thank you, Okie!
I haven't used either version enough to be able to tell you I saw any noticeable difference in the user interface. The ability to export documentation is about the only thing I have taken advantage of with the newer version. I have a vague memory of trying to use a keyboard shortcut to copy and paste something while using the old version and it didn't work, which reminded me that there are differences because it was something I had done many times with the newer one.
Thank you again!
So you end up with a ready to use program, right? No errors or warnings afterwards?
No errors or warnings. It just opens the file like normal.
I am not a Automation Direct programmer. I have done a lot of RS500 I have the DS5 software and I am able to look at the program. I am reaching...
1,177
Hello, I have a couple of problems with the directsoft 6 software. I couldn't find a previous answer, and uninstalling and reinstall hasn't...
1,484
Hey everyone, Working on a system with a Koyo DL06 processor and it's my first experience with them. I have DirectSoft 6 and we got the program...
2,337
All, I have a program that I am adding the counter on Rung 83 (see attached). The reset logic is exactly the same as on rung 84, but I can't seem...
3,959
I'm hurting here and really need help. I have an old machine running a AutomationDirect PLC 405. I have a data collection system that is...
1,711
