Directsoft directlogic dl06! Analog!
suhel
May 2014
venezuela
Hello!, I'm in desperate need for help!!
I'm currently using a DL6 DirectLogic, first time using it btw.
The thing is, I'm more of a Allen Bradley type of a guy, Love RSLogix and all of its components.
In RSLOGIX there was a command called SPC for analog inputs and outputs. I would like to know, how can I create an analog input and output on DirectSoft5, and which program similar to Emulate, and FactoryTalk could I download (Free) for DirectSoft5
Thanks in advance.
You can try here first:
http://www.automationdirect.com/static/manuals/d0optionsm/ch5.pdf
It has setup and programming examples. You have to initialize the card in your ladder logic to establish the position that the card is inserted and what memory location the raw values will go into. Then you can take the raw value and scale it to meaningful information.
Ohh well it helped! Thanks alot! I have an idea now, is there a way to simulate it?, so I can check if I'm going the right way?
The Click software is only for the Click CPU.
There is another CPU, the Do-more, whose software is free and has an emulator.
But both of these are for different CPUs than the original specification (DL-06).
I am not a Automation Direct programmer. I have done a lot of RS500 I have the DS5 software and I am able to look at the program. I am reaching...
1,177
Hello, I have a couple of problems with the directsoft 6 software. I couldn't find a previous answer, and uninstalling and reinstall hasn't...
1,485
Hello all, We have an old AutomationDirect DL405 (CPU 440) PLC, and we've been using DirectSOFT 5.3. Since we are NOT upgrading this PLC for a few...
2,263
Hey everyone, Working on a system with a Koyo DL06 processor and it's my first experience with them. I have DirectSoft 6 and we got the program...
2,337
All, I have a program that I am adding the counter on Rung 83 (see attached). The reset logic is exactly the same as on rung 84, but I can't seem...
3,960
