directsoft software for KOYO plc. forcing an input bit
Create a Dataview. Enter the address of the input under the Element column. To get the status of the input showing in the 'status' column make sure that the 'status' button, to the left of the Dataview button' is selected. If the 'Enable' column is not showing select the 'Edit' button at the top left of the dataview window. 'On' and 'Off' buttons appear. These are fully functional yet as the state of the input has control. Finally to enable 'forcing' or 'overriding' open the Options (labled as Opts) button in the standard line of buttons. Open the 'Data View' tab and within it the 'Display-1' tab. On the lower right select 'Override Bits'. To return control to the actual input turn the override off.
Back on the dataview the override 'on' and 'off' buttons appear. Click the 'override On' button and the 'O' symbol appears. Now the 'regular 'On' and 'Off' buttons are effective. Remember that in AD processors a power cycle will clear all overrides.
Also make sure that you are using a KSequence link. Note that not all Koyo PLC's will allow forcing. If the PLC does not appear to allow forcing, create a new rung 1 and set the bit in that rung. Delete the rung after you are done testing.
Hi everyone, I just wanted to know the part no. for the latest GX developer software that can link with Q03 CPU? i have version 8.01B which does...
4,547
:( AAAAUUUUGGGGHHHH...........HELP!!!! :( I'M ON THE JOB FROM HELL!!!!!! IT"S SUN. NIGHT, I'M IN AN OLD PROCESSING PLANT, ALONE, 6 HRS. FROM THE...
2,523
I am not a Automation Direct programmer. I have done a lot of RS500 I have the DS5 software and I am able to look at the program. I am reaching...
1,176
Hello, I have a couple of problems with the directsoft 6 software. I couldn't find a previous answer, and uninstalling and reinstall hasn't...
1,484
Hello all, We have an old AutomationDirect DL405 (CPU 440) PLC, and we've been using DirectSOFT 5.3. Since we are NOT upgrading this PLC for a few...
2,261
