Disconnect
Not if you need the door mechanically interlocked. I'd use WireGuy1950's recommendation assuming you don't have a huge power requirement; the bigger versions (>100A) get pretty pricey.
I agree thru door sux. When they get a little age/wear in the they don't want to line up correctly and are a real PITA
Observations on thru door disconnects.
1. As PLC Kid said they wear and then do not line up well
2. I always found it interesting seeing lockout tag hanging on door operator with door wide open and the breaker inside shut. Have done myself when got all wrapped up troubleshooting.
3. You still have the incoming line hot.
I much prefer an entirely separate disonnect.
Dan Bentler
Dan Bentler
I prefer a side slung disconnect separate of the enclosure for precisely this reason. Otherwise by our safety rules, I have to lock out the source breaker.
I use cable type disconnects usually from SQ D but ABB and Cutler Hammer also have them. Automation direct sells the cutler hammers. They have metal handles just like a disconnect handle so LOTO is not a problem. You also don't have to worry about alignment problems with it being a cable/flexible operator. All you really have to be concerned with is the panel depth.
335
Here's what happened, Operator turned on the disconnect for an auger while it was still running to cut power. Auger DID in fact turn off, but the...
366
Good afternoon PLCS.net! I have a very odd situation that is happening, and hoping someone has some insight. We have just laid out a new 10G...
668
This question is about a Q68TD-G-H01. When I disconnect the thermocouple connected to channel 8 of the module, I am expecting D111.F to go TRUE...
3,490
For those of you that design / build panels: Do you typically provide a fuse / circuit breaker on your main disconnect inside the panel? We...
16
5,141
