Discovered a new cross reference "feature" in RSLogix v20
Paul351W
Mar 2008
Northern Illinois
154
I just converted a new project from v16 to v20, and was working on cleaning up some things when I noticed something strange.
I had some tags aliased to an output card that I had removed from the I/O tree. When I tried to cross reference the tags, nothing would show up, but if I did a Ctrl-F in the logic window and searched for the tag name that way, it would find them.
As soon as I cleared the alias information for the affected tags, the cross reference worked properly again. I haven't went back and tried the same thing in v16, but I don't remember having that problem before.
I thought cross-reference only showed tags that are "in use", or tags that have been used in the program.
Different to Find, which can search the tag database.
The tags I referred to were used in the program. I think the software must have gotten confused/unhappy because of invalid alias data . As soon as I deleted the alias information for the tags, cross reference worked normally.
I recently "discovered" that the Animations dialog in FTV is modeless. You can leave it open and click on any other object to show its animation...
43
15,044
So I right clicked on my "1769 Bus" in I/O Configuration, in my Controller Organizer and saw this. I've been trying to look up what it means and...
3,585
In the past, we have used AB 1492 feed thru screw terminals a lot. Lead time on these with our distributor is terrible. Is there an almost...
137
In our production plant we have multiple different networks (subnets). IT dept have setup routing between them so different subnets can...
119
Is it possible to connect a PC with running WinCC Advanced or Unified to a siemens PLC such as S7-1200 across different subnets? The computers can...
98
