displaying ladder logic rungs on panelview plus 6
aybee
Jul 2015
vancouver
Hello all,
I want to immitate couple of rungs of the ladder on the panelview for troubleshooting purposes. Right now i have block transfers b/w the plc and the screen. I can get individual bits to the screen and use these tags to display the ladder, but i wanted to know if anyone is using anything like this.
Thanks,
what you can do is to display several tags in series on the screen and assign color for true or false for every tag, if all tags are true then everything is green and rung is excecuting completely.
Thanks for the reply,
I am at that stage right now. I have drawn out symbols to mimic the NO or NC. they go green when the corrosponding bit changes. So i can see if the rung is true if all the bits are green.
I was wondering if there is a better way that others have used
Only "automatic" way to do it I've ever seen is with the RSLadder plugin for RSView32, which doesn't help much because RSView32 is defunct and I'm pretty sure it's successor (FactoryTalk View) doesn't have anything like that.
I agree that RSLadder was pretty cool for its time, but it wasn't much of a seller and there's no modern equivalent.
Hey everyone and anyone that can lend a helping hand. I have a project that I am being asked to add some animations of Solidworks or "3D" models...
342
Using FTview ME to create an HMI screen. Simplest task is giving me trouble. How do I create an HMI tag that will allow the name of the current...
133
Hello Folks, plc : micrologix 1500 The analog output from the loadcell is given to the plc. Using the SCP function I have scaled it into an...
764
Hi Everyone, I am hoping a Red Lion Expert can point me in the right direction. I am experimenting with data logging on a CR3000 10" screen...
605
I’m a bit stuck on HMI (KTP-1200) programming… See the picture attached. The PASS or FAIL box should only appear when the toggle switch is...
1,076
