Displaying manuals and drawings on MP277
PeterW
Jun 2006
Calgary, AB
2,531
I'm looking at methods of displaying manuals and drawings on a 10" MP277 HMI which I'm programming with Wincc Flex 2007.
The method I believe I can use is to create webpages and invoke an IE call from one of the screens. Was thinking of a main index webpage, which can then link to other pages with the docs.
The only problem I can see is when the IE pops up all the toolbars are showing which means an op can then delve into the system. Is there a way to call the IE and disable the toolbars??
Or is there another easier way to do this without IE.. :rolleyes:
Just in case you were thinking along these ways, then there is a PDF Viewer, but only for MP377. You find it here:
C:\Program Files\Common Files\Siemens\PTProSave\AddOn\MS_PDF_Viewer
Somehow, the problem is that whatever method/program is used, it must be integrated into the WinCC Flex runtime, otherwise you get the problem that the viewer stays ontop, without the possiblity to navigate away from it.
I was looking for a PDF viewer but couldn't find one to run.
I've already had to reboot as I couldn't shutdown the IE window (y). I'm planning to develop a web set-up with a close IE command button on it (all I have to do is learn HTML in the next few hours :oops:).
If the MP277 is a touch version, then it would be simple for the operator to use the "close" button.
If it is a Key version, then you would need to attach a USB mouse for example.
That, or the operator must navigate with TAB.
I'm looking for a method to hide the toolbar as well, which means the little red button disappearing (did it manually and had to re-boot).
When I run IE its opens up the system to anyone who wants to poke around, so I need to hide the toolbar and find another way to close down.
Hey everyone and anyone that can lend a helping hand. I have a project that I am being asked to add some animations of Solidworks or "3D" models...
363
Using FTview ME to create an HMI screen. Simplest task is giving me trouble. How do I create an HMI tag that will allow the name of the current...
140
Hello Folks, plc : micrologix 1500 The analog output from the loadcell is given to the plc. Using the SCP function I have scaled it into an...
773
Hi Everyone, I am hoping a Red Lion Expert can point me in the right direction. I am experimenting with data logging on a CR3000 10" screen...
613
I’m a bit stuck on HMI (KTP-1200) programming… See the picture attached. The PASS or FAIL box should only appear when the toggle switch is...
1,091
