Displaying remaining time of the timer on HMI
interlock
May 2011
Middle East
29
Dear All,
Please see the attached screenshots.
Its a project available on Siemens website to show how to set time & how to display remaining time in WinCC Flex.
I'm interested in the latter - to display remaining time on the HMI screen.
I would appreciate if someone could answer the following questions:
* In the LAD the on-delay timer has DB10.DBW6 on its "BI" and DB10.DBW8 on its "BCD" terminals respectively.
(both of these data types have been declared as "WORD" in DB10).
May I know why in Wincc flex tags, DB10.DBW8 has been mentioned twice - once as type "Word" and second time as "Timer"??
* In WinCC screen properties section, the format has been declared as "Decimal" for DB10.DBW8 (which contradicts the above statements).
* In short, I understand , to display the remaining time on the HMI, tag DB10.DBW8 is being used.
Then, what is DB10.DBW6 doing in the WinCC Flex?
Can we not use DB10.DBW6 to display the remaining time?
Regards
Hey everyone and anyone that can lend a helping hand. I have a project that I am being asked to add some animations of Solidworks or "3D" models...
356
Using FTview ME to create an HMI screen. Simplest task is giving me trouble. How do I create an HMI tag that will allow the name of the current...
139
Hello Folks, plc : micrologix 1500 The analog output from the loadcell is given to the plc. Using the SCP function I have scaled it into an...
772
Hi Everyone, I am hoping a Red Lion Expert can point me in the right direction. I am experimenting with data logging on a CR3000 10" screen...
613
I’m a bit stuck on HMI (KTP-1200) programming… See the picture attached. The PASS or FAIL box should only appear when the toggle switch is...
1,089
