Displaying tim eon C-more panel from CLX
Jim G.
Nov 2007
Georgia
187
I would like to use the external clock source function to display time on a 15" C-more EA9 panel. The source would be a Logix processor. When I went to set up the tags in the C-more, I set them up as signed int 32. I referenced the tag in the program, and got an error "Error tag-058: Tag I/O type does not match Object type.
What do I need to do to display the CLX PLC time on the C-more?
Displaying time on a C-more from CLX
OK. I was able to get the clock on the C-more to read the PLC time. It was a matter of selecting external clock source in the C-more software and identifying the correct tags to reference in the CLX program. In this instance , the PLC clock is the master.
Now I would like to be able to adjust the PLC clock from the HMI.
Basically, be able to adjust for daylight savings time.
How might I do this?
Thanks.
Hey everyone and anyone that can lend a helping hand. I have a project that I am being asked to add some animations of Solidworks or "3D" models...
342
Using FTview ME to create an HMI screen. Simplest task is giving me trouble. How do I create an HMI tag that will allow the name of the current...
132
Hello Folks, plc : micrologix 1500 The analog output from the loadcell is given to the plc. Using the SCP function I have scaled it into an...
764
Hi Everyone, I am hoping a Red Lion Expert can point me in the right direction. I am experimenting with data logging on a CR3000 10" screen...
605
I’m a bit stuck on HMI (KTP-1200) programming… See the picture attached. The PASS or FAIL box should only appear when the toggle switch is...
1,076
