Distant connection to a PLC through a 3G industrial modem
mahmoud_ics
Apr 2012
Tunisia
Hi everybody,
I have a "REDLION, IndustrialPro Series Router, RAM-6000 Series Router" and i want to link it on an ethernet switch with an Allen Bradley Controllogix CPU and a PanelView.
I configured the distant link by having a private APN from an internet provider.
To have the possibility to read CPU data from a distant location, how can i proceed to configure it?
Is it necessary to install an HMI software in all distant equipment that will be used to read data?
Thank you in advance
If you have a private APN, you can only connect to your Controllogix/PanelView network remotely only if your computer (with HMI software or programming software) is connected to the same private APN on the cellular network. I am not sure if your cellular provider would give you VPN access from the general internet into their private network or not, you have to ask them.
A public APN would give you a public IP address, which would be accessible from any internet connection, but this is usually more expensive from the cellular provider.
The provider will give a private apn with a private fixed ip address.
The router has its web user interface with the possibility to configure IO by modbus addressing, but, in my architecture i do not have a read write module for modbus transfer data such as MCM module from Prosoft technology.
I want to know how can i proceed?
Well, instead of (or in addition to) the PanelView, it would be better to have a computer-based HMI (like FactoryTalk View, or CitectSCADA). Then you could install something like Teamviewer to remotely access the HMI computer from anywhere.
Hi, it's been a few years since I have posted in this group. I'm looking for a product of some sort that can connect a handful of I/O's a few...
4,362
I need to read and write I/O points that are 1500 feet away from a PLC-5/20. I will shortly have fiber run that distance in prep for the day that...
22
4,341
Hi dear . I have a system with cj1m cpu11 etn. previously NT 5z HMI was connected with plc. recently my old HMI got damaged. I want to replace it...
255
Hello gentlemen, Im working on a small project on TIA Portal, about establishing a Modbus TCP connection between my ET200SP plc and a socomec...
312
Hi all, My ethernet port on my laptop recently broke and I was hoping to just use a usb-c dongle in the mean time to go live on my PLC until I...
454
