DL06 W/H100 Ecom and Data Worx
Oleta
Aug 2005
Mexicali
Hi Every Body...
Years ago, i made a PLC(dl06) control based oven, but the problem came on data logging, couse i use data worx but in some times, dataworx cant be concected and stays saying pending, in the newer version of data worx they put a buton that test your conectivity, when i did it says fail.
Can any one solve some kind of problem, or recomend me another non expensive data loging, only need to log 4 temperature, and must be saved in .csv file.
Tnks.
Is your H0-ECOM at the latest firmware revision? If not, you should update it with Netdit.
File -> Live Update -> GO! This will download the latest firmware and booter packages.
Pick the H0-ECOM from the display list after downloading the firmware from the web and select update firmware. Depending on how old it is, you may also need to update the booter.
Tnks...
icky812 i already made it, and make the cpu access and every thing goes good, but the problem is DATAworx, it says pending, and nothing happends.
May be something on rll logic?
or data worx need special protocol, i installed the ipx protocol, tcp ip, i dont know what else to do!
If it still says pending then most likely the PLC is not sending data. Check your logic in the PLC against what Dataworx says the logic should be.
You can always send in an email or call our free technical support. We have Spanish speaking techs if you need one.
AutomationDirect.com Technical Support: 1(800) 633-0405 or (770) 844-4200 Email Tech Support
Hi, Mostly AB guy here with a little Koyo experience, but all of its digital. I get handed three analog I/O cards and asked to prove that they...
502
Hi all, I am making a test rig to be able to wire in any DL06 (or DL05) And create a HMI in red lions crimson 3.1 to test all the inputs and...
933
I have a Cmore screen which is communicating to the DL06 in BCD and need to create a timer that works in real numbers for a test, I simply need to...
2,148
I have a client that has many Automation Direct DL06 PLCs for a municipal water/wastewater system. When there is a power outage, one of the sites...
2,444
Hey everyone, Working on a system with a Koyo DL06 processor and it's my first experience with them. I have DirectSoft 6 and we got the program...
2,336
