Do More PLC hardware question?
Jul 2016
Illinois
Hello All,
I am working on a project to where I will be interfacing to multiple Do More PLC's via Modbus protocol (E-net connection) from my PC based Windows machine (running Windows7)...I'm looking for an expert w/ prior experience that can advise me in this subject.
I've done it a lot using custom protocols, but not MODBUS.
How many PLC's?
How much data are you moving?
Is this high speed?
What will be initiating the transactions?
Thanks for answering...Interfacing to 3 PLC, there will also be a C-more operator interface sharing the network. Speed will be limited to 100Mbps. As host, I will initiate an action to ultimately turn on/off a coil output.
Bring us up to speed.
Will the PC be doing anything other than developing the project, and maybe a bit of online activity?
Will the PC be controlling any of the DoMore actions?
Will the PC be required to be connected to the project for the project to work?
At the comms level between DoMore and CMore, it is Modbus.
The DoMore driver in the CMore will handle this (transparently - you won't need to know anything about Modbus for this.)
Do you need more Modbus activity than that?
The PC will always be connected to the PLC's, as software will be running on the PC that will be sending commands to the PLC's to ultimately turn slo-syn motors on/off.
The PC will not be connected for any online activity, however I will have remote access, via a VPV connection.
There won't be a lot of data moving back and forth...around 10bits per command.
Does all this seem do-able?
Hello, We are looking at a machine upgrade project, for which we will probably use a Do-More BRX PLC + 3 high speed I/O modules, to automate...
714
Hello, I been trying to sort some values in the the Do-more PLC but still have some issues. I have 20 elements from the data view with random...
3,675
I have a C-More EA9-T8CL that I'm trying to connect to a BRX DM1E-M PLC via ethernet. I have the IP addresses set as static 169.254.1.0 (PLC) and...
3,224
I have a project coming up in a few months where I'll be taking measurement from an LMI Gocator and sending them to a Do More PLC H2-DM1E. I...
1,049
Has any one connected the Cmore panel to an Omron NJ PLC if so how? I have been reading up on the FINS communication protocol, Seems a bit fuzzy...
2,550
