Do PanelViews cache domain accounts?
Evirua
Aug 2018
Here
34
I know the question doesn't matter in the case of a FactoryTalk user, whose authentication is processed -as I understand it- directly on the loaded application by FactoryTalk Security.
Windows-linked users however need a server to authenticate against.
I'm evaluating a scenario in which the HMI-to-server connection faults for some reason or other. Would Windows-linked users still be able to connect in the HMI? Via cache memory or other?
I've read people speculating that PanelViews don't cache accounts, but couldn't quite find a reliable source to confirm it.
For the sake of posterity, the answer is no; Windows CE does not cache authentication credentials, Windows Server does, which is only relevant when using FactoryTalk SE, not FactoryTalk ME.
Hello all, I have a question I hope someone can help with. I have boxes (a literal pallet of boxes) with old panelview 550, 600, 1000, etc. I am...
26
858
I have an application where I will be using two PanelView Plus 7s to run two machines that share a common processor. The machines are identical...
402
Can a Panelview Plus 1000 replace a Panelview? If so how? So far the Panelview Plus 1000 doesnt see the file from the Panelview. Thank You.
1,185
Hi! Small question. I have a customer currently that is reporting an issue of 2 different panelviews running the same application connecting to...
2,303
Hello PLCs.net! I am working on revamping my test bench in the lab, I was wondering if someone has had good luck with mounting panelviews without...
3,391
