Does Fanuc have free technical support ?
passwordg
Aug 2011
South Carolina
224
If I need technical assistance with a Fanuc robot, does Fanuc require a paid contract or do they offer any free support ?
Or maybe a free tier and a paid tier ?
Thank you.
GE and Fanuc severed their relationship several years ago. The number that NetNathan cited will get you technical support on GE PLCs, including those developed during the joint venture between GE and Fanuc. However, Fanuc robots were never part of the joint venture.
The best you could hope for by calling 1 800 GEFANUC would be that someone at GE, having fielded many questions about Fanuc robots, has looked up a contact number for Fanuc robotics tech support.
Good afternoon all, hope everyone is doing well. Could someone explain the pic attached on the wrt.not instruction? To me, it looks the same as...
2,143
I'm looking at iRConnect for a customer of ours and testing it to see if its a worthwhile solution, but it appears to me that it requires an...
3,211
On a ladder rung I have %Q0001 which does not relate to the output address on the PLC, what does it mean?
6,355
63
Hi, i am using DVP-14SS2 PLC, after program written to plc, when power is reset, plc doesn't run. always need to connect to pc for the run mode.
62
