Door Simulator Exercise 2
Hutch463
Feb 2011
North Carolina
Hello all! I'm VERY new to PLCs and ladder logic. I'm having a VERY hard time preventing my motor from bursting into flames in Door Simulator Exercise #2. What I have is attached. If it doesn't make sense, it's because I've tried every combination I know of, and lost track a ways back. I'm no far from gouging my eyes out with my pencil. Any hints, subtle pushes, or throwings off a cliff would be appreciated!
What events cause it to "burn up".
One problem I do see is if you press the "open" button, it seals in the "up" motor. But, if you then press the "close" button, the up motor seal in is not dropped out. The down motor will enegerize as well, and your motor will start on fire.
Start off by moving the XIO Close and XIO Open to the outside of the branch. If you press the close button while the open motor is running, it will stop running.
As a rule of thumb, when ever I program a machine, any time there are multiple outputs controlling a single actuator like this, which cannot be energized at the same time, I put an XIO of the opposite output as a permissive. Like in the case of a solenoid with two coils, if one coil is turned on, the other cannot be. This way if I make a mistake somewhere in my program and activated the steps in a sequence at the same time, the outputs still won't both come on, and I won't damage my solenoid.
I have got this #4 working,but I would like to know if I have missed anything or if there is a better way. Does it matter how many rungs you have...
2,590
I was having a bit of technical difficulty trying to upload this program file so I posted it as a jpg file instead.
1,339
Hello, I have a question about PLC application I am working on. http://thelearningpit.com/lp/doc/dl/dl-rl.html I am on excersise number 1. I...
2,328
I'm having trouble getting my garage door to work the way its been assigned to me. We just started using this in my controls class and my team...
15,922
I was wondering if someone has the ladder for this I want to check where I'm missing a switch. It has to do with the AJAR light. I can get it to...
3,581
