LogixPro Door Simulator
goodoboy
Aug 2010
Houston
86
Hello,
I have a question about PLC application I am working on. http://thelearningpit.com/lp/doc/dl/dl-rl.html
I am on excersise number 1. I am stuck at this problem:
If the Door is already fully opened, Pressing the Open Switch will Not energize the motor.
How do I not engerize the motor? I can not use latches for this problems.
I will use an AND logic with the both limit switches to determine if the door is fully open. Then determine how to de-engerize the motor. But how will I not engerize the motor.
I can only use the basic instructions for this problem.
Any hints will be great!! Thanks alot.
Hint: how do you energize the motor using the push button alone?
When you figure that out, just put the conditon of the limit as one of the condition.
Thanks Steve and harryting. See attachment so far. I got it working now and moving on. It took a lot of thought, but its getting there!
Feel free to comment or offer advice.
If the limit switch contacts are the same type (normally open or normally closed)then you need to look again at your rungs ;)
I'm having trouble getting my garage door to work the way its been assigned to me. We just started using this in my controls class and my team...
15,922
I am currently taking a begginers PLC class and our instructor has asked us to do the supplemental program #4 (Door Simulator) on the LogixPro CD...
8,226
Hello everyone, I have attached my printout of my Logixpro door simulation. Its all working fine but the only thing im having problems with is...
30
8,511
Ok, I am looking for criticism of my work on these door exercises. First is exercise 3... It works as it is supposed to so I am looking for...
19,474
Hi guys I decide to add manual and auto mode to door simulation in logixpro since many of automated processes have manual and auto mode. I solved...
11,029
