Double integer conversion
Hi, In Proficy Historian I have a tag connected with Double Integer / DWord configuration. In the PLC it is a Time format. Can that be a problem...
1,207
Hi I have an application need send some position data to Mitsubishi A800 drive via Modbus rtu. I have double integer value in plc. There are two...
2,961
Hi All, Now i get a problem about converting from Time string to double integer. I used FC37 to convert it but after converting it, DINT value got...
3,192
Hello everyone! I am trying to figure out how a word - 16 bit can be translated into a double integer (%MD) in Pl7 . Currently the application...
2,661
I have configured a ML 1100 for modbus communication through its serial port.Then moved a float value to two input registers.(decimal values in...
2,795
