Doubt in PLC ladder logic inputs usage
gandhi
Aug 2010
*******,Tamil Nadu
Hello guys,
I am new to this plc programming(only 2 months), so help me out here,
Can you tell me the how to use ladder logic for following operation.
In this application I have a single push button in the panel as a input to the PLC.
My operation should be as follows,
1) When I press the push button first time the PLC should be in a stand by mode where no process will be executed.
2) When the push button is pressed second time the PLC should go in a manual mode.
3) When third time the push button is pressed PLC should go to auto mode.
And again when i press the same push button PLC should go to step1.
Also there should be a time delay each time when the push button is pressed.
you can use the up counter and equal to block,,when conter is equal to 1 raise a memory bit,similarly for all..reset the counter with third memory bit.hope it works
Questions about an old SAIA PLC type PLC is PCD4 - board RS422 (PCD7.F110) We sold a HMI to replace one but our HMI doesn´t communicate with the...
1,090
hi, i am new to this field i have a doubt why we use functional blocks in plc programming and how to use these functional blocks in programming...
25
8,220
Hello members, I have written a code for following program but my only doubt is about addressing of auxiliary contacts that are used for...
17
4,300
Hi all, I am new to plc and new to here. I am learning PLC using the free software PSIM from learningpit.com. I want to clarify how this code...
2,588
Dear friend Can anybody tell me what is the differenc between PLC and DCS(distributed control system).and what is the real meaning of...
4,924
