doubt on Master-slave(distributed control) motion control application...
s_viswesh
Oct 2002
I have a doubt on a motion control application(shoulder-elbow-wrist configured robot).
The application has 3 axis of motion each controlled by an "axis controller" hardware
with a DSP. Basically the axis controllers run a 1 ms servoloop in which it does PID
calculations. I also have a "master controller" hardware with a DSP. The master controller
sends signal over a CAN network to the axis controllers for start of motion, stopping motion,
co-ordinated motion etc. Currently I have a servoSynch cable running from "master controller" to each of "axis controllers". Basically the servosynch cable carries a 1 ms pulse train generated by the master controller. My doubt is : Is this separate cable needed to synch the axis controllers. I.e. If it is possible to program the axis controller to interrupt themselves every 1 ms, then can I get rid of this servoSynch cable and just have the communiction cables(CAN) between the master & slave? What is the common practice in such master-slave(distributed control) configurations?
regards
Viswesh
I have never worked with a system like you describe, but I do have a thought on it.
It sounds like the ServoSynch cable might be there to insure that the master and slave controllers are always in communications in "real" time. I don't think you can count on a typical network signal for this type of safety. Usually they will have some communications delay time that you gotta allow for different "packet" sizes and so on. You may need this second cable for safety alone.
Steve.
Hello Guys, Hope everyone is doing well. I have a general doubt about ladder programming. The outputs are not getting energized when I used the...
1,877
Hi all, I'm working with FTVS and I'm trying to give a title to a dynamic popup that shows what device it is currently operating. I've seen that...
1,941
Hi all, I'm quite new to the automation world. I've used a bit Tia Portal in the last month and now i have a new working in rslogix 5000. From...
5,065
Hello everyone! I'm currently programming a safety logic on Studio 5000 Logix Designer V33.00.00 and I wanted to know if there's a way to test...
1,589
hi all, I'm working on Studio5000, structured text language. I have several buildings and for one of each several BOOL alarms in an array...
2,021
