Downgrade project from Factory Talk SE v8 to v7
JRoss
Sep 2006
Dillsburg, PA
184
Running into a wall here, and wondering if anybody has trucks up their sleeves for this. My first time using SE, and I naively used the most recent version of studio (8.1) to develop screen graphics. Now I need to import them into the customers network project, which is on version 7. I'm finding out there is NO support for this, which is a big hitch. I'm hoping someone out there has a workaround.
Try exporting screens to *.XML file, then import.
Is there a big difference between SE and ME.
I develop in ME 8.0 pretty frequently and down load to 7.0.
When converting to an .MER and as your saving it you have the option to change the name the version number.
Is that the same for SE?
I'm probably all wet here but isn't something about the first three lines of the exported .xml file that needs to be changed before importing into the 7.0 version.
OK, got it. I found this old thread that gave me the information needed.
Now that I'm not under the gun, here's some more info. ME is for Panelviews. SE is Rockwell answer to SCADA, and can be used in local mode on a standalone computer, or on a network in a distributed system. The studio environment is basically the same for both, though SE in general has more capability.
Here's my list of failed attempts:
  • Deploy application in older version. This is what I'm used to in ME, but isn't an option with SE. You're stuck with the version of the development environment.
  • Directly import the display files from the project folder. This worked for parameter files, but the display files gave me an error.
  • Export the displays to XML and import. This gave me an error that the "schema" did not exist. This is the file that Studio uses to parse the XML, and the v8 schema wasn't available.
  • Modify the XML file to use the v6 schema (used for both v6 and v7 of Studio). Returned a parse error. The v8 schema must be different from v6.
  • Copy the v8 schema into the appropriate folder. The schema was not recognized as valid.
  • Open up two VM, one with Studio v7, one with Studio v8. Copy and paste the graphics between them. The graphics came across completely garbled and unusable.
  • Convert v8 SE application to ME, compile into v6 runtime, use Studio v6 to decompile, then reconvert to v6 SE. Couldn't even get the SE application into ME.
Finally I did some searching and found the above mentioned link and essentially followed those instructions, substituting the correct version numbers for my case. I got an error during import, but everything seemed to work. I still had to import parameter files, tags, alarms, etc. separately, but this was much better than rebuilding from scratch.
So.... I know that this is "impossible" (looking at what Google has to say about it). But I still need to achieve it....somehow. Just completed a...
6,836
Hello Everybody I have a problem of project version : I developed a program for a client on Rslogix studio 5000 , project version is 24 and i...
9,167
Hi all, Ive just spent 2 days doing mods to an intouch version 8 project, stupidly, without thinking i upgraded it to version 9 because thats...
21,074
Hey all, I am trying to change a program version from V20 to V16. Rockwell has the answer in this file...
729
Hi Everyone, Is it Possible to downgrade to Program from version 32 to 24version..? Because I have 24 version and the program which I am going to...
1,089
