Downgrading 1756-L61 Program to 1756-L1
Feb 2007
home
66
I have working programme installed on 1756-L61, for some purposes I need to install at my lab controller which is 1756-L1. I have rev 13 and 17 RSLogix 5000. I tried to change the controller from drop-down list to 1756-L1 but it does not show any rev and therefore this simple method does not work. Please help me out.
L1 processors can use firmware versions 13 and below. What is the version of the L62 program that you are trying to download to it. The software will not automatically create a rev. less than the one it was created on. There are technotes that will describe menthods that may work to change say a version 17 program to version 13.
I went from version 21 to version 13 of the software. I uninstalled the version 21 software, and followed the clean up process in tech note...
922
Hello, We upgraded our PLC to L85 but then realized that some old software no longer runs with it. We still have the old PLC, but we can't...
2,358
I have several Modicon Quantum 140CPU43412A controllers that I want to downgrade from Unity OS to Concept OS. I first swing at it was to use the...
1,570
So I have an L62 and want to use an EDS for a device. I need the newer version of the firmware (using 20.11). I realized the CPU in my test bench...
3,359
Can anyone direct me to some instruction for downgrading to firmware on the Modicon Momentum PLC's by Scheinder. In need of V1.11 Thanks!
1,474
