CCW Crashes After Downgrading Version
Relay0828
Feb 2023
Ohio
I went from version 21 to version 13 of the software. I uninstalled the version 21 software, and followed the clean up process in tech note QA34332 and installed version 13. The software opens, but when I click on discover (or any other option that tries to communicate with hardware) it crashes. I know downgrading versions past version 20 of the software causes problems, but I can not seem to figure out how to get the software to stop crashing. Any tips?
I have no direct advice to help with your exact situation but I will say the best solution for you if you need to have multiple versions of CCW on your machine is to have multiple VM's each with a different version that you need.
Did you find a solution for this. I have the same issue.
Hello. Has anyone ran into an issue with HSC on 2080-LC20. It run a cut off press and every so often after resetting to 0 it does not count...
63
I am running CCW 13 trying to upload to a micro 820 vers.12 I get an output message OPC server is unable to load project controller. Please help!
237
How to retain Values in CCW software? I am using CCW software and I can not find the Retain function in this software. Not even local or global...
171
I am new In a CCW and as a beginner I am trying to learn programming but i am noticing that my CCW software is taking around 1 minute to download...
107
