Download to red lion G308 via serial port.
DLMUK
Jun 2013
Southampton
311
I am going to try and download a database to a G308 via the serial port.
Reading the Crimson 3.0 manual I cannot find anything about port settings. I know the baud rate for a PAX meter on C2 was 38400 but does any know if this is the case for C3 and a G308?
I cannot use the ethernet or USB option as the current database has corrupted.
usually the default Baud rate is 9600 - not sure about Bit / parity
the PAX is rs485 if my memory is right
PAX is 232/485/usb depending on the option card you put in it. Baud rate is 9600 as default for 485/232 comms.
I'm just not sure that the baud rate is 9600 for 232 when uploading a database.
Cheers,
this is the Red Lion default setup for PAX modules
:confused: if it has been changed
My understanding is that with a G308 and Crimson 3 the Crimson software will do the baud rate behind the scenes and you never have to worry about it. Just figuring out the right COM port on the computer.
Hi all, I'm having programs connecting to a G304K2 over Ethernet to transfer the screens. I know on the older models, you first had to do a...
3,318
I have a Red Lion DSPZR with the Ethernet option card (XCENET) installed. While I can access the unit's web page remotely using the address of the...
2,198
Good day everyone, bit of a problem, I have a Red Lion DSPZR that I have been working with, yesterday was loading database programs fine, now...
1,989
I can't go online with a program that is "identical" to what is running on the processor. I attempted to go online with a processor today with...
2,181
XV was working. Now, following download, not working. Turn it on at the display and it fails. Thought it was the return status not coming back...
1,551
