Power?
dhillon,
Do you have the panelview hooked up to the PLC? If not, if I remember right it does not supply its own power for communications. I know I had to buy a power supply to use our panelviews at the test bench with out a PLC. This was not the line power for the panel, it was just for the comms and used the same cable that connects the panel to the PLC if I remember right. This may be the problem for you. Another problem I had was that I did not have the right firmware selected in panelbuilder32. I do not have the software infront of me and do not remember how to change it off the top of my head.
Larry
