drive tuning
Jeanne
Jun 2005
I have a question about AC drive tuning. What will happen if I misinput the value of kilowatts? For example, It should be 23Kw, but I input the 33Kw. I suppose other values are correct.
I assume you are referring to the motor data entry parameters where the software asks for the motor nameplate horsepower or kw. If you are running the drive in open loop V/Hz mode, I don't see any problem as long as you have entered nameplate current correctly.
In sensorless vector or flux vector mode, it is unlikely that the drive will even operate since the motor model will be way off from the actual motor. In the more precise sensorless vector models, you would not even be able to do a motor ID run or pretune run because the drive will sense the error and refuse to finish the ID run.
Thank you very much.
I have another question. The motor nameplate is horsepower. The software asks for Kw. I use horsepower value times 746. Do I still need to divided by efficiency to get the Kw entry value?
No. Multiply the hp by .746 (note the decimal point) and enter that as kw.
On some drives that I am familiar with, the unit for motor power will change when you change the drive language parameter. For example, for German, Italian, Japanese, Swedish, English, the units are metric (kw). But, if you select English (American), the units become Imperial (hp).
Happy Friday! I have a two axis system made up of: ControlLogix L73 @ firmware version 24 1756-EN2T @ firmware 4 Two Kinetix 350 servo drives...
3,173
I was looking for books on drive tuning, and came up to this one : 'Elektrische Vorschubantriebe in der Automatisierungstechnik' from Hans Groß...
1,727
One table is operated by ac motor and motor is drive by Sinamics S120 drive. The table carry steel coil. and the table went through 4...
3,068
Hi.. I am using 200 HP Flexpak3000 with field current regulator board installed. Analog DC Tacho with data 180V/1800RPM, 500 VDC and 252 Amps...
3,954
Hello all, I am currently trying to program a PowerFlex 525, version 7.0. We had a power outage recently and when the power was restored, the...
291
