DriveTop for Indramat
Been using DriveTop for years. If you find a manual, let me know.
They haven't exactly been good at documenting things the last few years, but it has gotten better lately.
The help files you likely need are the firmware help files. It is a bit much to get used to, but, the firmware is as important a question as the software.
I agree with Rick,
I have more than three years by now and I never seen an manual or tutorial/samples how to use the DriveTop.
What they have are actual drives/firmware manuals attached to program or CD ( still a good thing because trying to get them in order from their site is a real pain )
References about DriveTop you will find into firmware manuals ( you have to dig a little bit ) or from Indramat guys themselves, maybe you will be more lucky, mine most of the time they come with the answer "you should go to training"....
In case you will still find one I will really appreciate if you can share it with us.
Regards
Marian
Get the drive help CD. It will link in with drivetop. Drivetop will shortcut to the appropiate place help file for the screen you are on.
There really is no manual for drivetop, as the screens/menus change with every drive version.
It may be of some help to look at the help files for SYNTOP, if you're using a spindle drive (electronic line shaft). Most of the DriveTop functions are available in SynTop, in a fashion. The DriveTop oscope function is much more flexible, for instance, but these are minor differences. The drive firmware is the key, ...
DriveTop DIAX4 RS232 Connection problem
Hello dear experts,
I try to connect to DIAX04-SSE-03VRS / HDS03.2-W075N-H.
- Cables IKB0003 IKB0005
- RS232 Connection/ try 9600 Baud 19600 baud.
- DriveTop16 version.
I have 6 drivers. And try all them. no connection
DriveTop installed on WindowsXp and Windows7 but no connection.
Please help me. :) What should I do?
Regards
Hi, guys, how are you? If we want to install a new/different gearbox on the line, could you tell us where and how to set up gear ratio in...
2,768
I can't get the DDE server software- driveserver.exe to run. It shuts down immediately. Anyone see this problem before? Nothing in the event...
7,446
I have DriveTop 16V04 software but can't support the diax02 driver. it just supports diax03 and upper. I need the lower version of DriveTop but in...
3,911
anyone have drive top earlier version..? need to extract from an old drive and dump into like replacement ecodrive dk1.01 or something like...
2,545
Hello, what program is it used to connect with laptop a rexroth indradrive HDS02.2-W040N-H(verry old model), i'm guessing because its old so on a...
1,309
