duplicating ifix picture
cjjeeper
Aug 2018
Nowhere
71
Sorta a dumb question but...
I want to duplicate a picture to work on some changes to the graphic..
so "picOriginal", I want a copy of that and will name it "picOriginal_1"
do I just copy that in the windows directory and then rename it?
Seems to work but not sure if this is the best way to do it.
At the end of editing I will want to replace the "picOriginal" with the changes so that is not obvious to me either. Delete the "picOriginal" and rename the "picOriginal_1" to "picOriginal"? or is that going to break the calls to the picture from the existing menu etc?
Thanks in advance
I open the picture in workspace and do a save as. I save it with the original name to a different folder on my computer. When I am done making changes to the picture I either copy and paste it back into the pic folder or open it and do a save as the pic folder.
interesting...I looked for but must have missed the "save as"...
So if it's saved in a different folder it will run from there when I hit "control-W"?
I copied a panel in factory talk HMI for an identical system. The label names are still the same as the original panel but I am trying to change...
143
Hello Everyone, I have multiple machines that do the same thing, only the IP's are different. Some of the machines have AB drives while others...
1,239
Reading Bering C Sparky's thread about his seafaring adventures (Congrats on the new job by the way),led me to the discussion about Stage...
2,294
How would you aaproach duplicating the Scale with Parameters command in another plc like EzAutomation Touch PLC of which they do not have any...
4,255
Hi, I have a HMI MP277 which is currently installed in the customers factory. The customer would like another HMI exactly the same as the first...
4,126
