E1000 and E-Designer easy one - I hope
AntonScot
Feb 2016
Highlands
Hi All,
I think I may have missed something but how do you put a static text message on all the screens (blocks) of a E1000 e-designer project?
Without adding it to all the screens one by one.
My customer wants a "pump in manual" message to appear on all there screens.
As the automatic control cannot work with a pump in manual.
Cheers
Anton
Create a block with the text on it, and then set it as the backgound block for all screens. You will have to select the background for each screen though, I don't think you can make it happen to all at once.
Yes it's copy n paste I'm afraid
But, if you copy the static text with ctrl/c then open each block and using ctrl/v
All the attributes are saved and it will paste into the same place on every page
So it doesn't take so long - mouse in right hand opening blocks and left hand ctrl/v.
Cheers everyone,
Just noticed the Background block thing thanks Bryan.
And Ronnie, I know from experience the copy and paste doesn't take as long as you think, its just a PITA when you change the IO point of the wording or something.
I am looking to upgrade a CompactLogix on V18 to an L83E on V32 which is currently using a Beijer E1151. Does anyone know if the E1151 is directly...
646
Hello there! first of all: Happy new year!! I was wondering if you can help me find out what's the meaning of a Motorola's ACE1000 CPU...
1,109
Does anyone out there have any experience programming these RTU's with ladder (codesys)? We have a guy that does our programming in C, but its...
4,207
Hello again, I bumbed once again problem with E1000 panel. Program has been converted from E600 to E1000 series without problems. Panel...
2,426
Hi all, Could someone post me one e1000 series recipe file, so I could verify the format of data inside the recipe file. I have 151 old recipe...
2,702
