mitsubishi/beijer e1000 alarm problem
viikku
Jan 2010
H
Hello again,
I bumbed once again problem with E1000 panel. Program has been converted from E600 to E1000 series without problems. Panel communicates with PLC (mitsu A2SH), but everytime I start any of the conveyors I get alarm conserning the conveyor. And when panel is powered up there will be couple of alarms already. Cable is checked, panel has latest driver for PLC, alarm list has been compared with old panel, there's no newer firmware for panel...Running out of ideas here :) Anyone seen this kind of problem before?:site:
I would suspect you have alarms because you have some 'digital signal is OFF/ON' configured wrong.
On the alarms tab check the alarms you are having and check whether the signal/bit should be off or on to cause the alarm.
Found the problem. E-Designer 7.52 build 347 had driver for A2SH that wasn't working. I had to install build 344 to get older driver. Development for the drivers is stopped couple of years ago, says Beijer.
Hi all, Could someone post me one e1000 series recipe file, so I could verify the format of data inside the recipe file. I have 151 old recipe...
2,703
Hi all, I upgraded from e600 to e1060, because of a backlight error in e600 (yes, faulty backlight locked all buttons in e600. service guys from...
2,825
Hi all, I'm hoping someone can help me with obtaining firmware files for a Beijer E700 HMI terminal. I'm looking for v4 firmware. I have an HMI...
2,769
Sadly I am in the unfortunate position to try and get an old FX0s-10MR-ES talking to a Beijer ix-T4A over serial. This is my first use of either...
1,747
I'm trying to locate V5.01 firmware .bin file for the Beijer / Mitsubishi E300. Does anyone have a copy of this they can send me? I've tried...
2,367
