e900 to a1s comms probs
Ds@Cepha
Sep 2010
worcestershire
im having problems connecting a e900 hmi to a mitsubishi a1s PLC, the hmi is downloading from edesigner properly via RS232, however when downloading is conmplete an error message apears on the HMI telling me "SYSTEM ERROR NO PLC port" and the only option it gives me is to restart the HMI, where the same error message appears again. the PLC is connected to the HMI via the apropriate CAB18 RS422 cable. any help would be greatly apreciated.
Haven't seen that error but my best guess is that you haven't set the port to use to communicate with the PLC. Go to Setup / Peripherals / and drag the controller to the RS422 port.
Bryan
have just cracked it, as i have only got one PLC connected at the moment, it was searching for the PLC defined in the second peripheral controller. but thankyou as i wouldnt have found this if i hadnt have looked in that area. (y)
Hello Expert, I'm now with Honeywell Products. Can some one advise which connection setting to be used during HMI development using HCi Designer...
1,549
Hi It maybe a long shot but a customers E900 hmi has gone down, they have a spare but we don't have the firmware to flash it to v6.1. Does anyone...
1,874
Hi all, I have been tasked with uploading a project from a E900 mitsi panel but the only connection I can see is RS232 going to the PLC. Would...
1,088
Hi, I see everyone of you in this forum have much knowledge about plc, and I'm very new in this things. Maybe someone willingly will help me out...
1,454
Hi, I have a E900 which I have been making adjustments to for a couple of hours today. It has been no bother, transferring the project about 5...
3,818
