ea-mlogix-cbl to a1747-cp3
Pete Dazer
Nov 2013
Plymouth, MI
I've got an ml-1400 inside of a sealed can, with a cmore hmi connected with the standard automation direct cable. Can I simply use two breakout boards and connect rx to tx and tx to rx, with the common, for a simple three wire connection to my cp3 for programming purposes?
Thanks in advance,
Pete
[email protected]
It's not clear to me exactly what you are trying to do. But a simple three wire connection to the ML1400's serial port is all you need to make the connection.
If you are trying to connect to the same port the HMI is connected to the HMI will have to be disconnected. You would need some additional hardware(port splitters) for that. Unless the protocol is DH485.
You mentioned a 1747-CP3 cable, it's a null-modem cable. Crossing the TX and RX wires again would turn the whole cable back to a straight thru.( if I read your description correctly).
Thanks Mickey!
I just need to do some edits, and with the PLC sealed up in a NEMA7 XP can, my only point of access is that AD.COM cable. As soon as I'm finished back in the HMI it goes!!
Pete
hi everyone, i have a problem with the ip of my plc 1400 micrologix. someone of my coworkers deleted the ip of the plc and i donk know how put...
2,021
HI Can MICROLOGIX 1000 can be connected directly to PV 300 and if so which type of PV. Thanking you all
20
4,220
Hi all, I'm attempting to measure the network bandwidth requirements from Logix 500 to an SLC and Micrologix. The programming software is on...
1,619
Hello all, I am trying to poll data into a MicroLogix 1100 from a PLC 5/40E over Ethernet I/P. My MicroLogix program contains a single message...
5,494
The manual for the 1761-NET-AIC shows connecting a PC to DH485 network with a 1761-PM-02 cable. Is this done using a DF1 driver set to...
1,071
