Eaton ELC programming
viper7986
May 2014
Texas
Need help programming an Eaton PLC, I have a analog add-on module and need assistance on how to program it so i can turn an input on based on the 4-20ma input.
I'm going from memory here but I believe there is a wizard that helps write the code for integrating analog I/O modules.
The wizard will install code in the program that moves the data from the analog input to the data register you specify.
They are pretty low level but actually quite powerful if you can wade through the hoops. The instruction that amazed me most when I found it was one that takes latitude, longitude and time and spits out coordinates to point at the sun for optimal solar energy.
Other things are frustrating until you understand them as well. Like you don't specify the time base of a timer, certain timers have certain time bases and that's that (unless you flip a certain bit then some of them change...ya?)
Same with whether or not memory addresses are retentive or not. Certain addresses are and the rest aren't.
Different processors have different register/memory layouts so you have to be looking at the right place in the manual or you could get in trouble.
Looking for some help on the red lion side I was able to diver out all the port settings to get the hmi to talk to elc having the are-485 light to...
1,105
Hi everyone. I am newer to the PLC world. I was trained on mostly Allen Bradley and Rockwell stuff. Long story short. I have never used the Eaton...
2,506
Hello! My name is Richard and I'm hoping to pick the brain-trust here about the Eaton ELC and which Allen Bradley PLC is most comparable. I'm a...
10,583
Hi all, Does anyone have any experience with the Eaton PB series PLC? I have one on the way for a project and after digging thru the manual have...
1,904
Hello, I’m new to this forum and if I’m posting incorrectly let me know. I’ve been having an issue I can’t seem to figure out. I’m sure it’s...
124
