Hi all,
I have a press machine with an eddy current drive that is presently operating with the motor at 460 vac 60 Hz 3 phase. It is a 15 HP drive. This machine is destined to go overseas where the power is 380 vac 50 Hz. The control board on this takes 115 vac and states 47-62 Hz so that is not a concern, but what about the motor? We're running this at a low enough speed that I'm sure I can just turn the pot up to match existing speeds. Does anyone have any experience with eddy current drives? What will likely happen to it when we lower the voltage and frequency by 20%
