EDS File Error
ccaltagi
Oct 2011
Austin, TX
I am trying to create a EDS file to describe a device.
I started from a template and used EZ-EDS to create the file.
While it opens fine with EZ-EDS, opening it with the Rockwell EDS Hardware Installation tools returns errors:
The following error occured in the [Assembly] section of the EDS file: The data format of 'Member Reference' field in [Assem1] in entry 'System Online'.
The following error occured in the [Assembly] section of the EDS file: The data format of 'Member Reference' field in [Assem2] in entry 'BOOL 0'.
Is there an obvious error in the file? I don't understand the error codes returned by the Rockwell software.
Thanks in advance for your help.
Here is the section of the EDS file that causes problems:
[Assembly]
Assem1 =
"Input",
500,
0x0300,
1,"System Online",
1,"Inspection Loaded",
1,"Inspection in Progress",
1,"Camera Ready",
1,"Inspection Busy",
1,"Image Acquisition in Progress",
1,"Image Acquisition Done",
1,"BOOL 7",
1,"BOOL 8",
1,"BOOL 9",
1,"BOOL 10",
1,"BOOL 11",
1,"BOOL 12",
1,"BOOL 13",
1,"BOOL 14",
1,"BOOL 15",
1,"BOOL 16",
1,"BOOL 17",
1,"BOOL 18",
1,"BOOL 19",
1,"BOOL 20",
1,"BOOL 21",
1,"BOOL 22",
1,"BOOL 23",
1,"BOOL 24",
1,"BOOL 25",
1,"BOOL 26",
1,"BOOL 27",
1,"BOOL 28",
1,"BOOL 29",
1,"BOOL 30",
1,"BOOL 31",
8,"SINT 0",
8,"SINT 1",
8,"SINT 2",
8,"SINT 3",
8,"SINT 4",
8,"SINT 5",
8,"SINT 6",
8,"SINT 7",
8,"SINT 8",
8,"SINT 9",
8,"SINT 10",
8,"SINT 11",
16,"INT 0",
16,"INT 1",
16,"INT 2",
16,"INT 3",
16,"INT 4",
16,"INT 5",
16,"INT 6",
16,"INT 7",
16,"INT 8",
16,"INT 9",
16,"INT 10",
16,"INT 11",
32,"DINT 0",
32,"DINT 1",
32,"DINT 2",
32,"DINT 3",
32,"DINT 4",
32,"DINT 5",
32,"DINT 6",
32,"DINT 7",
32,"DINT 8",
32,"DINT 9",
32,"DINT 10",
32,"DINT 11",
32,"REAL 0",
32,"REAL 1",
32,"REAL 2",
32,"REAL 3",
32,"REAL 4",
32,"REAL 5",
32,"REAL 6",
32,"REAL 7",
32,"REAL 8",
32,"REAL 9",
32,"REAL 10",
32,"REAL 11",
364,"STRING 0";
Assem2 =
"Output",
496,
0x0100,
1,"BOOL 0",
1,"BOOL 1",
1,"BOOL 2",
1,"BOOL 3",
1,"BOOL 4",
1,"BOOL 5",
1,"BOOL 6",
1,"BOOL 7",
1,"BOOL 8",
1,"BOOL 9",
1,"BOOL 10",
1,"BOOL 11",
1,"BOOL 12",
1,"BOOL 13",
1,"BOOL 14",
1,"BOOL 15",
1,"BOOL 16",
1,"BOOL 17",
1,"BOOL 18",
1,"BOOL 19",
1,"BOOL 20",
1,"BOOL 21",
1,"BOOL 22",
1,"BOOL 23",
1,"BOOL 24",
1,"BOOL 25",
1,"BOOL 26",
1,"BOOL 27",
1,"BOOL 28",
1,"BOOL 29",
1,"BOOL 30",
1,"BOOL 31",
8,"SINT 0",
8,"SINT 1",
8,"SINT 2",
8,"SINT 3",
8,"SINT 4",
8,"SINT 5",
8,"SINT 6",
8,"SINT 7",
8,"SINT 8",
8,"SINT 9",
8,"SINT 10",
8,"SINT 11",
16,"INT 0",
16,"INT 1",
16,"INT 2",
16,"INT 3",
16,"INT 4",
16,"INT 5",
16,"INT 6",
16,"INT 7",
16,"INT 8",
16,"INT 9",
16,"INT 10",
16,"INT 11",
32,"DINT 0",
32,"DINT 1",
32,"DINT 2",
32,"DINT 3",
32,"DINT 4",
32,"DINT 5",
32,"DINT 6",
32,"DINT 7",
32,"DINT 8",
32,"DINT 9",
32,"DINT 10",
32,"DINT 11",
32,"REAL 0",
32,"REAL 1",
32,"REAL 2",
32,"REAL 3",
32,"REAL 4",
32,"REAL 5",
32,"REAL 6",
32,"REAL 7",
32,"REAL 8",
32,"REAL 9",
32,"REAL 10",
32,"REAL 11",
360,"STRING 0";
No, this is for a National Instruments Vision System. I made some progress since my first post. Changing the Assembly section to something like the following fixes the errors, but I wanted to give users more granularity over the default members of each assembly, instead of defining it as a big block. In our vision configurable software, we define the content of each assembly as described in my first post, and I wanted to reflect that in the EDS file.
Is that possible? Is there a specific syntax to do that?
Thanks.
[Assembly]
Assem1 =
"Input",
500,
0x0300,
4000,Assem1;
Assem2 =
"Output",
496,
0x0100,
3968,Assem2;
Sorry I have never built an EDS. I would reverse engineer a file that I already have and a device I understood.
Hi all, I have been attempting to create an EDS file for a simple earth leakage relay, not many inputs and even fewer outputs. I am using the...
5,093
Hi, I got the ESD file for a PowerFlex 70 from the Allen Bradley web page. But, when I want to add it to the RSNetworx a message pops up and tell...
5,405
2,919
Hey y'all!! I'm looking for an old EDS file, GSE 560. I can't find them anywhere. It is for a GSE560 display on a DeviceNet network, with...
76
Hello, This product that I have the 1790D-T8BV8B is discontinued, does anyone have the EDS file for it? I wonder if TechConnect will have this...
188
