EEPROM and PLC ranges
tested
Feb 2010
germany
Can someone help me with the following questions:
1. What is the use of an EEPROM in a PLC?
2. Why do PLC's have IO ranges such as 2048 and not 2000?
Tested
EEPROM's have absolutely no reason to be in a PLC. The only real way of having secure memory is to actually burn a ROM. EEPROM's are much too affected by cosmic rays.
2048 is SOooooooo much better then 2000, no? It's just marketing. Old, boring PLC's used to have only 2000 available I/O, then some marketing genius figured out that if they added a couple more transistors, they could sell a 2048 I/O model. It's kind of the reverse of "19.99" is psychologically much cheaper then "20.00".
We have a PLC-5 in a printing machine. Few weeks ago, I made some online change in the running program of PLC but did not burn in to EEPROM. So...
4,874
Hi. I have a 222 CPU. I need to recover the program from the eeprom memory. Is it possible?
98
"(S44) PLC requested action has failed" Result when WRITE the RAM program to the EEPROM. No pre-confirmation message first. VERIFY fails too...
1,405
Hello I have a couple of processors a 5/01 and a 5/02 both with eeproms When i try to load program onto either eeprom with either processor a...
4,807
Hi all, yesterday I was at a customer site doing a PM and after making a couple of minor mods to the program, I went to back it up to EEPROM (yes...
2,402
