Electric actuator (instead of pneumatic cyl)
panic mode
May 2003
Toronto, Canada
1,963
Hi everyone,
Just thought to pick your brains:
We have small application where small actuator is required to extend or retract pin to lock two frames.
Normally this would be done by cylinder but unfortunately, this is out of question in this case,
the actuator has to be electric but we don't really want to go for linear servo or robo cylinder.
An ideal candidate:
- stroke of about 1 inch (25mm)
- force of 150N or so should be ok
- speed is not critical (up to 10-15sec is ok)
- should be compact (about 3"x3"x3" or smaller of possible)
- panel space is at premium so anything without drive/controller would be huge plus
- either AC or DC powered - prefereably DC (could be stepper)
- delivery 3-weeks (or better)
Any suggestions?
I'm looking for electric rotary actuator with field bus.
1,176
I have an electric actuator with a 75% duty cycle. I am sending an analog output from a PID to a controller board on the actuator. My concern is...
2,424
Hello. need a bit of help here. i am trying to control an electric actuator ball valve to maintain a specific flow of water. the valve doesn't...
23
5,805
I have used electric actuators for many years to operate Adjustable Port Valves made by the company "North American". I have used several brands...
2,299
Dear All, I need to buy electric actuator and its spares of a actuator installed here....the actuator is supplied by german party and I have...
2,913
