Recommendation for Electric Rotary Actuator.
You need to define the operation better. Modulating? Three phase or single phase? Quarter turn or multiturn? New valve or retrofit? Valve type and size? Ambient conditions? Analog position and feedback?
I strongly recommend a consult with a couple of good local suppliers.
I've had good luck with Rotork. For precise control you can't beat Rexa. Auma is big in Canda. RCS is low cost. I've had issues with Limitorque. I'm not sure which of these have comm protocols.
I have worked on small projects using AB Micrologix but now we want to take a photo, process it online, and sort based on returned variables...
324
Just looking for recommendation on what others are using for switches. I'm working on a parts list for a project. I need 40 ports...
1,494
We have a 5 Ton Rheem A/C unit at home We only run it in the Summertime, and sometimes in the Fall. It does have a habit of blowing fuses at...
18
2,484
Hello, Does anyone have a recommendation for a Modbus TCP remote IO. It pains me to have to use one. but yeah. Just standard remote IO with like...
1,255
Greetings! I have an application where I am going to use IFM E12354 field wireable M12 D-Coded Ethernet connectors. (url below). I have...
1,169
