Apparently your knowledge of electricity may have a few weak spots. You cannot place a sensor in the water that will detect current, unless you have TWO points of differing potential to measure. My point was, for the purposes of developing such a detection system, you COULD put animals in a type of cage that would provide these TWO necessary points to measure. Just placing a sensor in water only gives you ONE reference point. Current has to flow between TWO points. Now you might use TWO separate electrodes, located some distance apart, and measure the stray electrical current between the two sensors. To do that, practically ANY type of metallic plate would work, with an insulated wire from each pad connected back to a miliampere meter. It would probably be best to use some metal that is resistant to seawater corrosion, such as stainless steel, nickel, or platinum.I am familar with how voltage is captured. I understand how electricity works. What I am looking for is a sensor or creation of a sensor that can be placed in the water that will detect it. This is not to cage an animal but to study and understand how they work.
Im thinking voltage (output from fish)? ohms(water)? if you have E and R? I=E/RI am looking for a way to detect minute traces of electricity in water
Possibly some type of magnetometer could be used to measure animal-generated electric fields. However, the environmental noise in a typical body of water is going to be difficult to filter out, due to the low levels of animal electromagnetic field transmission (very low levels approximately 1 X 10−7 Teslas).
A superconducting quantum interference device (SQUID) is a type of magnetometer that can measure very weak fields, based on superconducting loops containing Jopsephson junctions. SQUIDs can measure electric fields down to about 5 x 10−18 Teslas. The next question is whether an underwater SQUID sensor loop is available, and if it can be tuned to the frequency ranges that animals generate.
