Electronically-variable potentiometer
rguimond
Jul 2009
Escuminac
666
Can anyone recommend a 10K potentiometer that can be controlled from an analog source (0-10V or 4-20mA)? Obviously, this isn't a potentiometer with a manual adjustment screw.
I have an application where I need a remotely controlled reg, from a PLC. Any suggestions on brands and lines to look at? Anything with 1/4 -...
3,161
67
I'm upgrading an existing machine with a Honeywell HC900 controller, and I'm trying to do some data processing in the controller. I have variables...
71
dear all.. i am designing the Sea Water Intake pump which the 4 pumps will be operated parallel, and 1 pump will be as stand by pump The pump data...
167
I have a old lathe with a 120 VCA 9.5 AMP motor. Has white, black and red wires. I need to find a way to connect it to a variable speed controler...
103
