old lathe with 120 VCS 9.5 AMP Variable control board out
honeycanya
Mar 2024
Tulsa
I have a old lathe with a 120 VCA 9.5 AMP motor. Has white, black and red wires. I need to find a way to connect it to a variable speed controler. It controler needs to have a way to control the speed of the motor. The original board use a Potentiometer. Any help would be appreciated.
Hello every body, I need your help to restart an old KITAMURA KMC-50 cnc lathe with 2 TA FANUC controll. This old lathe was lying unused/powered...
1,869
This is admittedly a pretty obscure problem, but maybe someone else has run into it, or at least something similar. For reasons I won't get into...
133
Does Rockwell still offer reset codes for old school Master Disk floppy's? In a bind and need to reset the activation disk soon and to be pointed...
230
Has anyone found a way to convert/replace/update the firmware on old Parker TS80xx series HMIs (i.e. TS8010, TS8006, etc) to accept Crimson...
93
Hey all, I am currently working on a depalletizer for a customer and we are doing a hoist upgrade. This is a SLC500 processor and the drives are...
300
