Emerson FM-2 Indexer Modbus Codes?
ndzied1
Aug 2002
Chicago, Illinois
2,857
Hello:
I've been given the task of troubleshooting a system that contains an Emerson FM-2 servo indexing module/ An AB Micrologix 1200 and a RedLion CL20 HMI.
The RedLion is communicating w/ the FM-2 over Modbus and using some code (for instance 32042) to read/write to different parameters in the drive. While Emerson seems to have all kinds of manuals on line and free software too :) I'm having some trouble locating the list of these modbus codes.
Has anyone done this before and could possible point me in the right direction here to the secret codes?>....
Does anyone know if it is possible to create a help file that would, when a user presses F1, bring up a custom help (that I made) about my...
100
Two questions for GE/Emerson e.g. PACSystemsRX3i (CPE330): 1. Is it possible to use 2D arrays inside a function as a local member? (I can only...
92
gents, I am trying to configure communication with EMERSON PK300 controller through port A1 using generic ethernet communication module . I could...
135
Hi there, I'm doing some extensive testing and commissioning with a slew of new Emerson PACSystems RX3i PLCs. It would be convenient to...
137
Hi there, Trying to get some ascii serial communications working via RS485 (COMMREQ functions). I have attached our wiring for the COM2...
1,001
