ZestyMozzarella
Hi everyone, I have a new Rx3i I installed on a line. The MAIN program has an indicator for CPU health activated as good so long as %SC09 is OFF. %SC09 is a system variable that is set to trigger ON whenever any fault occurs in the CPU. I additionally have a rung that whenever %SC09 is ON, it triggers a CPU not healthy output that shuts my machine down which I want to happen when something relevant happens.
Issue is the new Rx3i CPU triggers a LAN transceiver fault; OFF network until fixed every time I disconnect from the CPU. I have no intention of having this port plugged in unless I'm accessing it with my PC myself. It doesn't need to connect to anything and is local.
The problem is I don't see a way to stop this from triggering in the diagnositcs as a fault which then triggers my %SC09 code rung which shuts my machine down. Is there a way to tell the CPU this is not a fault condition or is this a non-editable inherent habit of the CPU's? I suppose I could use something like %SC14...I think for now I might just put a dummy switch in to satisfy the ping check.
Thanks for any advice, starting to research the manuals now to find a bypass solution if one exists. I'd prefer not to change the code if I can help it.
