Emerson/Rosemont 644 Temp change DegC to DefF
ndzied1
Aug 2002
Chicago, Illinois
2,857
We have some Rosemont 644 temperature transducers that came in as DegC and I need to chenge them to DegF. They have HART but I don't have any HART equipment right now.
Emerson will do this for a very expensive service call.
Does anyone know if I can just get a USB to HART converter and change it with some free/ relatively cheap software?
what is it hooked up, to controller wise?
if it is a hart compatible Logix5000 card I have changed settings via plc code before however going this route on a production system without a HART calibrator to rollback if you change the wrong parameter may be ill-advised.
also some asset management software works with the 1756 hart series cards, but not sure if you can get cheap AMS software
I am assuming you do not have the LCD display on your particular tx.
Your best bet may be to see if a local contractor with some type of hart comms capability can come out and do it for you. I would think this would be your cheapest option as it will be a short service call fee.
We don't connect it to anything. We just make a power unit that has these units. The customer does all the final connections.
They do have displays though.
Two questions for GE/Emerson e.g. PACSystemsRX3i (CPE330): 1. Is it possible to use 2D arrays inside a function as a local member? (I can only...
58
gents, I am trying to configure communication with EMERSON PK300 controller through port A1 using generic ethernet communication module . I could...
115
Hi there, I'm doing some extensive testing and commissioning with a slew of new Emerson PACSystems RX3i PLCs. It would be convenient to...
113
Hi there, Trying to get some ascii serial communications working via RS485 (COMMREQ functions). I have attached our wiring for the COM2...
985
Hello all, First time poster, long time viewer of these forums. Could not find my solution on here. We have had issues with a Comm Fail on an...
401
