Emulate a PLC and it's functionalities using Pi
kihtrak
Apr 2016
Fullerton
Hello there,
If I'd like to "emulate" a PLC (available in market) using a Raspberry Pi 3 (the HMI and other I/O operations should just resemble like the original PLC), what are the steps that I need to go through? Kindly advise me on this. Any detailed explanation would be highly appreciated.
P.S. - Am trying to do a project on "Securing PLCs" using "honeypot" method.
You can run Codesys on an rPI. You can download the runtime directly from them, and use the development software and program like you would any Codesys based PLC. Includes webvisu for a basic HMI.
I use that for testing/practice, works fine for me. The free version runs for 2 hours. After a reboot of your PI it will run another two hours, etc. For €50 you can buy an unlimited license (for one PI) to get rid of the 2 hrs limitation.
codesys V3 is good to test security issues, and you can use your program in many PLC types as codesys is used in many factories of plc.
Got lost in middle..:/
Hello everyone,
First of all, thank you all for the help.
As I told before, am trying to emulate the Allen Bradley PLC functionalities using rPI. The reason is to secure the actual industrial PLCs, by having this emulated PLC serve as a "honeypot" ( in simple terms, to evade a cyber physical attack ).
To accomplish the above task, my idea is as follows: If possible, design a microcontroller ( or something ) that can actually sense the difference between the actual PLC and the emulated PLC . ( I've to prove to the board of members, that my emulated PLC is pretty close enough to the actual PLC. The other plan is to have some ethical hackers try to attack my emulated PLC and see if they can find out the "fake" one. )
How can I make this ( the bold text ) happen using Codesys on rPI?
Well you are not because Codesys is not Allen bradley. Codesys was a suggestion because it emulates a Codesys based controller on an rPI because Codesys has developed a runtime for it. So for emulating a PLC for the purpose of using it for actual PLC purposes it's a good suggestion assuming there was flexibility with the platform (ie...testing/educational).
Given what your after I don't think you'll have much luck. Even if you could build something to "emulate" a logix PLC, I'd guess it's be pretty easy to identify if the 'target' is an actual Logix or not by identifying if it is running VxWorks, the operating system it uses.
Why not just get an actual AB PLC? If you are talking security, surely there has to be much better options out there than something hacked on an rPI???
Originally it was just a PLC available in market.
As far I know, Codesys is a software for programming PLCs, not for emulating a specific PLC brand.
There're several papers on internet about PLC honeypots. I found one titled "CryPLH: Protecting Smart Energy Systems from Targeted Attacks with a PLC Honeypot"; it seems a good start for getting a better understanding of the theme.
Guess, I can go around it to have a better understanding of how a software for PLC can be run on rPI.
Exactly! We are trying to bring out shortcomings like these, which might lead us to the actual solution. ( Since it's a research! )
With the allocated grant, it's not quite possible to buy one !:( We might get some chance to work on an actual AB PLC in an industry ( I highly doubt this! ). But, if not do you think is there a way out?
Thanks a ton! It might help us a lot. I'll keep you posted on this.
Hello Experts, I'm wondering if this has been done before if possible to create an Emulate file that have motion control axis? I tried to...
151
Hello there, Is it possible to use RSLogix series to actually emulate a Allen Bradley PLC? To touch base, we're trying to find the...
2,043
Hey all, Am trying to run a program that contains a SFC routine with RSEmulate 5. It is giving me a problem saying "Error loading RSP file!"...
1,598
I have two PLC programs running in RSLogix Emulate 5, and I am trying to set up a message command so that one PLC can read data from the other...
5,906
Hello, I need help. I am making an automation project for my grade, and I need to simulate a PLC AB MicroLogix 1100 and 1500, but that's not the...
7,833
