emulating analog inputs in RS Logix
buhnen
May 2008
Somewhereland
131
Hi again folks,
I've programmed a routine for real time averaging of an analog input but I won't have the chance to check whether it works or not untill tomorrow when back in the working installation where my CompactLogix CPU is.
Unfortunately it seems that the Emulate 5000 doesn't allow to emulate analog I/O so I was wondering if the RSLogix 5000 does include any kind of ramping instruction which might be helpful for this. Looking through the online help I've seen an instruction called S-Curve (SCRV) but at first glance it seems too complex to set it up (lots of parametres included).
I just wanted to ask you all if there is any other option to this instruction, even an Add-on, or if it's better should I start thinking of programming my own code for a ramp.
Thanks in advance for your answers.
I'm fairly beginner when it comes to these sort of things. Previously when I worked on systems, we just used a test bench that we could remotely...
982
Hello everyone! I'm currently programming a safety logic on Studio 5000 Logix Designer V33.00.00 and I wanted to know if there's a way to test...
1,596
Hello Guys, I am trying to emulate FT View project in Emulator V30.00 . I can already emulate the processor and download the program but when I...
2,125
Hi, I am intending to emulate a ControlLogix 5571 PLC (on qemu probably). I am looking for relevant information about the CPU architecture, but...
1,888
Hi all, We are trying to make a SoftPLC communicate with a server, but can't seem to make it work. A possible cause is the following error we see...
1,942
