EMV grounding machine
rQx
Oct 2010
Trelleborg
1,051
Our customer has bought a machine a CNC wood cutting machine. It states that it need a seperate 16mm2 EMV"ground" in addition to our 5G16mm2 supply. It's no problem we have close to it. But I wonder why? Ive seen VFDs have a requirement of 16mm2 ground but that is only for the supply.
I have never seen this before and I find only little information about it. The installer said that this is mandatory and standard way to do it and it should always do like this because of high frequency noise. But that we in Sweden fail to do it.
Edit: also they stated that the impedance Ohm of this should be under 5 Ohm. That is very high and the power supply cable would also fulfill this
Thoughts?
Hi all, I'm connecting several 4-20mA sensors together in parallel (only one shown below) The enclosure is ABS plastic with metal backplate DAQ...
274
I have Rhino 120 to 24 dc power supply and it has 2 Positive and 2 negative terminals on the DC side but no ground terminal. Should I connect one...
435
I have a Beckhoff PLC with many AI modules. Most devices are loop powered using the same +24 VDC power as the Beckhoff Bus Coupler and all is...
668
I was once asked a question in a job interview. "Do you ground both ends of a shield?" I answered: "You only ground one end". Apparently that was...
4,952
Hi all, dont know if this forum is the correct one, but I know many here could answer this question.. There is a project, where a subcontractor...
2,149
