The best solution to connect two LANs to a single ControlLogix is a Network Address Translation (NAT) device.
Rockwell sells one of their own (9300-ENA), and there are plenty of devices that will provide that sort of routing service on the market.
I would have to disagree that NAT is the best solution. It depends on what kind of networks he is joining and he did not provide us with that detail.
If it's all for factory floor comms and to maintain OEM IP Addresses or put all the equipment on a common subnet then yes NAT is the best solution but if he is tying his PLC to the corporate network then for security reasons a VLAN is better as a VLAN isolates and a NAT simply translates.
I've never seen an industrial NAT device that didn't include a firewall.
Firewalls would be even better isolation than a VLAN, as long as the rules are configured correctly.
In a VLAN, the traffic is passed together from switch to switch, and the network relies on the correct management of every switch to keep that traffic separate.
If you want one device to be part of two different VLANs, this can be very difficult to accomplish depending on the vendor and how the VLANs are defined.
