encoder counts and mm
helloankur
Jun 2015
new delhi
let me know the use linear equations , there is a pressure roller i want to ove it by 50 mm pl let me know how to use encoder pulses . encoder counts is 4000 and movement is 50 mm.
Which roller is the encoder attached to?
Identify that roller, then calculate the circumference of it. That is how far the outside of that roller will travel in one revolution.
Then you will have Distance per Revolution and Pulses per Revolution.
Divide your Distance per Revolution by your Pulses per Revolution, and you will end up with Distance per Pulse.
there is linear encoder attached to 110 dia which go fwd and rev with 50 mm of encoder counts.
i have to use relation b/w required pos in mm and encoder counts.
this roller will go fwd and rev only .and encoder will counts .
now we van use linear equation.
x,y
y= encoder counts
x=pos in mm which drive from trigonometry equations.
now i have to comepare both value and trigger on/off signal for sol. for fwd and rev to maintain the pos in mm.
if you can give me E-mail of yours?
for better conversation.
Hi all, I am implementing an incremental encoder sensor (ABZ) to replace the existing "manual" encoder wheel I have in my device. This is a 360...
170
Hello, I am trying to take the counts I am getting on my plc from an incremental encoder and use them to keep track of position. I have never...
1,332
Hi, I am using Siemens CPU 314C with encoder counts. I am also using input I1.4 for zero channel latch value. Encoder is fitted on roller and...
1,531
Hello fellow members :) We are trying to refresh an old production line in paper bag packaging industry. We are using Sick NT6 contrast sensor...
1,561
I am running into some problems trying to trigger a camera to take a picture every 15 degrees when I spin the part I am looking at one full...
3,627
